It is currently Tue Aug 05, 2025 9:25 pm
 Post subject: pore filling cocobolo
PostPosted: Thu Jul 12, 2018 4:07 pm
Last Name: Weber
City: Canajoharie
State: New York
Zip/Postal Code: 13317
Can you use GLUEBOOST Fill n' Finish to fill the pores on the back and sides of a cocobolo guitar and will a shellac finish be OK on top. Thank john
PostPosted: Thu Jul 12, 2018 4:22 pm
First name: Freeman
Last Name: Keller
Don't know about the GlueBoost, John, but the last guitar I built out of coco I pore filled with Zpoxy after giving it a good alcohol wipe. There was still quite a bit of red that came up into the epoxy. I was also paranoid about red migrating from the coco to the maple purfling strips so I did some of the binding after the coco was epoxied.
A long time ago I did a little test on some koa with Zpoxy, thin CA and standard paste filler - I felt that the Zpoxy did a better job of popping the figure. And I personally react so badly to any CA that I would be terrified using it as pore filler - I have to wear a respirator any time I work with the stuff.
Also, sorry, I can't comment on shellac. I use it sometimes as a base coat or to seal wood but not as a finish in itself.
These users thanked the author Freeman for the post: john weber (Thu Jul 12, 2018 4:44 pm)
PostPosted: Thu Jul 12, 2018 5:59 pm
Shellac is pretty much well known to stick to anything. I used Star Bond on a recent guitar though it was not Cocobolo and French Polished it. CA is an amazing filler if you ask me. I will most certainly be using it again.
The obvious answer is.... Make a test panel and find out for yourself.
These users thanked the author jfmckenna for the post: john weber (Fri Jul 13, 2018 7:50 am)
PostPosted: Fri Jul 13, 2018 8:19 am
Last Name: Weber
City: Canajoharie
State: New York
Thanks for the info. and great looking guitar thanks john
Users browsing this forum: dofthesea and 44 guests
